Although the lights are probably not ADR compliant, my suggestion would be to run them anyway. Reasons being; Hella make OEM equipment and probably issue a TUV certificate.
If you do get a defect notice with the lights, you then have the option of taking the car with your TUV certificate to a engineer to get it cleared. As far as I know, TUV standards are the best, and most engineers will agree and pass you.
Good luck on the purchase and install!!!
