Please test the voltage from the D+ wire which is the small blue one on the alternator, not the large battery cable as most do. This is what tuirns the light off and will give the voltage at which the alt is putting out. The 0.2v you have checked is the earth which is correct. Check it at idle, check it with consumers on and sometimes you will , in your case most likely have to go for a drive with the multi connected up, extend the leads, go for a drive and watch that D+ puts out and observe as much as you can. Seen it before where itll check out good and then intermittently drop whilst driving, different loads etc certain rpms etc, hope that makes sense, seen it before many times been checked by sparkies and still ends up being the alt or at least the reg.
Good luck
Jmac
Alba European
