Please dont kill anymore vr6's
you sound like a enviromentalist!!! should be a bumper sticker!!! hahaha
heads up you vr6'rs!!!!!! heed the warning!!!
Guys if you have problems with your heater core leaking DO NOT just block off the pipes that go into the heater core and the return . Make sure that you rejoin them if you are going to delete the heater core from the system. i have seen about 4 cars now with the pipe blocked and this line is the main water line for the head.
!!With this blocked your motor will DIE !!
Make sure you rejoin the pipes to create a complete circuit for the water to flow.
what i will do when my heatercore leaks is run some radiator sealant through the system the core is leaking already so you car is wet, its worth a try and im sure it would work.
cheers brenton
MK1 4door
MK2VR6
MK3VR6
Transporter
and untold wrecks
i did this that. It was lucky i left the bleeder line on. mine survived.
i bought mine blocked and is fine?! go figure . . .![]()
you can block off the heater core but you have to join the pipes on the motor
MK1 4door
MK2VR6
MK3VR6
Transporter
and untold wrecks
Sorry brenton guys, how can I check if mine is blocked?
the hose that goes from behind the head and tee's off to the throttle body. will go up to the firewall and connect to the heatercore, this pipe is the one holden mech's always block off. it has to be joined to the pipe that came of the other end of the heater core. if you just follow the pipe from the back of the head and make sure that it joins back into the system .
cheers brenton
MK1 4door
MK2VR6
MK3VR6
Transporter
and untold wrecks
Mine blew on Monday that heater hose from the back of the engine to the firewall getting a new one put in![]()
My heater core is leaking so i bypassed it. Just got a U bent pipe for the 2 pipes. Its gotta be better the blocking it completely.
2000 SAAB 9-5 Aero - Stage 2. 275hp 420Nm, Brew City Boost
1986 SAAB 900 Turbo 16 S
