ABS light comes on and off as it feels like it!
My ABS light comes on and then goes off the very next time i start the car?
Some days it does, some days it doesn't!
WHATS GOING ON ANYONE?
Could be a few things, does it come on after you set off down the road?
Most likely to be a sensor.
Best way to find it is with a VAG-COM scan. Failing that you can check the resistance and output of each of the sensors with a multimeter.
The front ones can be got at from under the bonnet, the rears have connectors under the back seats.
yeah i have the same prob with mine, stays on most of the time now, sometimes stays off on a trip. took it to vw village, they said it's a common problem with mk3's, usually means the ABS is rooted, could just be a sensor thing though,
- You may not post replies
- You may not edit your posts
Forum Rules
