Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Air con re-gas?
    Aug 2007
    if you have a leak you do not need to fully gas the system you half fill and half with nitrogen same difference reach your pressure and check for UV or sniffer test then evac the sytem and fix the bugga
    Alba European
    Sep 2006
    Banff, Canada
    A little Mk3 air-con advice, and a recollection of my A/C pain!
    http://www.vwwatercooled.org.au/newf...ht=pain+thread
    Enjoy!!!
    JHN
    Canadian dubs coming to VWwA soon
    Dec 2006
    Kilsyth, VIC
    Quote Originally Posted by Jimmymac View Post
    If the compressor is cutting in and out you have too much gas in the system. Over charge causes this. Also check that your fans are working when you switch the system on. If not what is happening is that the condensor gets too hot thus pressure rises and the high pressure switch shuts the sytem down. It cools down again and the compressor cuts in again and so and so forth. Check ya fans mate and no harm getting a set of gauges hooked up to check your sytem pressure.
    CHeers
    My fans are screwy or at least the control for them is, High speed is now by manual switch otherwise it's full on all the time. BUT I do turn it on whenever I turn on the AC so it shouldn't be a factor.
    As for an overgassed system, hey it could be. The guys who looked at mine last time said they can't really do a service in Winter since in the cold the system never presurises properly so they said to bring it back when it's warmer.... so about now Will work it out eventually in my case even if it means replacing the whole system
    Mar 2007
    Just had my A/C done.. the details of the original problem are on another post.. new compressor, hoses and regas for just under $1000. after market compressor, but seems to work well.. hopefully the non genuine bits will last the distance..
    Feb 2007
    im a pom from the UK, but am living in Oz for a while...
    Beancounter,
    can you give us details of the aftermarket compressor and the price please
    I am interested to find out where you got it from and part number.
    is it a direct fit?
    did you do it yourself? and if so how hard was it?
    thanks
    Thierry
    Mar 2007
    sorry for the delay pommygolfer, got the details on the compressor
    as far as i can tell (label is forward facing and partially obscured) it is a Sanden compressor, model SD7HIS?? I was told that it was above the rated capacity of the original compressor, but I cant vouch for that.. the hottest day we have had in melbourne since i have had it fitted was 27 degrees, and i had to have the window down a little as it was too cold in the car, seems ok.
    as for fitting it, to swap the compressors would be a pretty simple job i suspect, it looks like a direct fit? but pressurising the system, leak testing it, fixing the leaks, that is well out of my league.
    hope that helps
    bc
    Dec 2006
    Kilsyth, VIC
    Quote Originally Posted by beancounter View Post
    I had to have the window down a little as it was too cold in the car
    Air con can never get too cold... ever.
    In short I want my air con to be like yours...
