Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: agg motor, need help serious!!
    gona try a couple more things and if i cant sort it, it will go to the vw dealer. to nice a car to just give up on it. cheers bud!!
    thanks wally thats a comprehensive solution if ever i heard it. gona set aside some time and give it a go. thanks a mill . il let you know how it goes.
    urika!!! fixxed it. timing is fine, fuel lines are fine. turns out its something to do with the starter motor or the ecu. i discovered that if i start the car and let the revs build up to the 5k switch the ignition off then quickly turn it back on and let the momentum of the motor kick it off again she revs all the way upto the red. cheers for the help fellas im a happy camper. also im thinking of instaling a racing camshaft any reliable aftermarket cams out there????
    Aug 2007
    Another thing to think about is, If the ECU is not getting a Vehicle speed sensor signal it will impose a rev limit of 5000.
    1979 Mk1 Golf 2door (Under construction)
    1994 Mk3 Golf VR6T, Autronic SM4, GT30r, Peloquin, 288mm Brakes, B&G coilovers
    2000 Audi S4 Imola Wagon, Stage 3, J-fonz tune, F21's, ER SMIC, 034 DP's, JHM DTS, JHM Trio Short Shift, 350mm Brembo 6-pot, ABT coilovers, BBS CH, RNS-E, FBSW, Alpha 2.5 cat back
    Dec 2007
    Somewhere in Melbourne, Victoria
    I had the same issue, using the VAG-COM I found a Hall Sender Signal error, this was due to the dizzy being slightly out-ie timing. A local mechanic might be able to adjust it when you next get a tune up
    1991 Golf GTI Manual - Tornado Red (Little Red Wagen)
    1998 Golf Cabriolet Manual - Black Magic Pearl (aka Rommel's Panzer) Deceased/written off
    1993 Golf Cabriolet Manual - Alpine White (aka Hitler Youth Wagen) Deceased/written off
    1976 Golf LS Manual - Bronco Brown (aka Roadrunner) Deceased/worn out
