Page 1 of 8 123 ... LastLast
Results 1 to 10 of 71
Thread: Aftermarket rims
    Sep 2006
    West Sydney
    Aftermarket rims
    Hi guys,
    Not planning to buy any as of yet, but just want to know so I can come back to it when I do.
    What kind of info would I need when going about buying aftermarket rims? E.g. offsets, ideal diameter, rim width (how wide can I go to get it looking snug), bolt pattern etc.?
    Feb 2006
    Camberwell, Victoria
    4x100 with a centre bore of 67.1
    Offset will determine how it sits in the guards... If they are tucked under the guards too much, then get some spacers, they will bring the offset down...
    Depending on state regulations, you can't go any wider than 2" from stock, so you'll be limited to 8", or 8.5" if going off the VR6... But diameter isn't limited...
    I have 17x7, but people rock 16x9 in the states... And the bigger the rim, the smaller the tyres, and the harder and more annoying the ride...especially with 205/40R17
    Sep 2006
    West Sydney
    Thanks for the informative post golf3. Makes it much more easier trying to digest all the numbers.
    Why is it that the ride is more harder and annoying with bigger rims with low profiles? Just that there's not so much air and flex in it than "normal"?
    Apr 2006
    Carlton, VIC (HK now)
    i reckon its because theres a bigger road contact, causing the ride having more frequent vibration...
    Point Cook, Vic
    low profile tyres have very stiff sidewalls usually. thats why they give a harsh ride
    normal tyres especially at modest pressures able to absorb a lot of road imperfections.
    FOLLOW US ON FACEBOOK
    Jun 2006
    i just went in, saw rims that i like, nagotiate for a better deal and rubber and drow off with new wheels
    brackie Guest
    Something we shouldn't forget
    Car companies (especially VW/Audi) put millions of $$$s into R&D and then design chassis and suspension to get the model to handle, brake and corner as safely and reliably as possible. It's a great thing to mod your car to make it look good and comply with the latest fashion trends, but you have to be careful not to go to extremes as you may compromise the original design goals of the manufacturer. Wheel diameter and tyre profile are a case in point as the "looks" benefit and sharper handling is somewhat reined in by a harsher ride. It would also be a huge disappointment if you went out and spent 1000s of $$$s and found that you didn't like what you got. Try before you buy if you can
    Jan 2006
    I recently added 17x7 with 205x40 toyo proxes on my 1997 gl. On a smooth surface they are great, much better than stock. One problem...there are no smooth roads in Brisbane, basically it has trashed my ride and I can actually hear my car falling apart. It has 212,000 on the clock and I'm adding k's quickly but it's geting so bad i'm thinking of cutting out my second muffler to add note so I dont have to hear my passenger side door card rattle. I'm sure 16's must suit the car better. The 17's do look good though.
    Sep 2006
    West Sydney
    Damn.. I'll have to keep that in mind when I go looking around.
    You put up a good point there brackie; it's not like they design a car and then just chuck it out on to the market. The Golf is my first car though, so I really wanna try out what it feels like to customise your own car a bit.
    As for the "try before you buy", can you really do that with wheel shops? Or did you just mean ask for a drive from a friend who has that kind of set up?
    Point Cook, Vic
    On a mk3 its widely accepted that 16" rims give a nice compromise between performance and comfort. Only probly is the range of 16" rims available in australia is quite pathetic! I went to the trouble of importing my own in a style i liked.
Similar Threads
  1. Vr6 rims
    By sdw1 in forum Mk3 Golf & Vento
    Last Post: 12-02-2007, 07:10 PM
  2. MK 4 rims
    By the_turbo in forum Wheels & Suspension
    Last Post: 17-09-2006, 01:05 AM
  3. Legality of aftermarket ecu?
    By ausgolfer in forum Tuning and Performance (inc ECU upgrades)
    Last Post: 15-07-2006, 08:49 AM
