Results 1 to 2 of 2
Thread: Advice wanted re side mirror
    Jun 2007
    My left side wing mirror was completely smashed by some hoon (deliberately) a few years ago. I just got it taken off and the cables were cut off as they were attached to the old broken mirror and the hole was taped over.
    Is there a simple fix e.g a Mk 3 mirror without internal cabling I can just stick on and adjust manually?
    Camden, Sydney
    Is this for a Passat or a Mk3??
    All VW Mirrors are similar but not the same.
    I can probably find you either a Passat or Golf one, just confirm which car it is.
    Re : THe cut wires, if you took the door trim off, there is a plug you can simply plug the new wiring into.
