Results 1 to 5 of 5
Thread: Advice needed, weird noise after changing cabin filter.
    Jun 2013
    Leichhardt, NSW
    I decided to change my cabin filter last night (black as all F..K). Removed old one, replaced with new one, all donr in 5 minutes.
    When I went to turn on the fan this Morning, the fan now makes a noise as it is spinning. if you turn the phone to 2,3,4.. the noise gets louder ans the fan turns faster..
    I doubt that changing the filter would cause this noise. I pulled the filter out and tested again and it still makes the noise. Possible something could have fallen down the duct when removing the old one like a leaf or something which is knicking the fan itself which would then cause the noise.?
    Anyone else experienced this problem?
    Any help appreciated...
    Mar 2013
    Brisbane QLD
    It will be a leaf fallen in....try putting the fan on full speed with hot air...usually the leaf goes brittle and ends up chopped up and spits out the vents if you are lucky...usually works...VDUB...
    VOLKSWAGEN TECHNICIAN - 16 YEARS OF PAIN..
    VCDS CODING- FAULT DIAGNOSIS - PRE PURCHASE INSPECTIONS- REPAIRS
    9W2 BT KITS -$300 - 9W7 BT KITS - $450 - CANBUS UPGRADE $150
    BRISBANE / GOLD COAST
    Dec 2008
    Sydney/Canberra
    Yeah, I'd say some of the crap that was sitting on top of the old filter has fallen in, and made its way down to the fan.
    Easy to do, given the location. As mentionened, blast it out on the #4 setting.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Jun 2013
    Leichhardt, NSW
    sweet. i might even get a can of pressurised air and try and blast the **** out. On the up note, force in which air comes out of vents has improved 100%
    Jan 2006
    Lowood Qld
    mine dropped down from its base and sreamed so i removed fan and put in 3 self tappers to hold it with contact cement to retain them 4 ever
    (if it's a serious probl.)
    german - english translations esp vw documents!!
    Dismantling 95 Seat Cord'a and 73 campers and 74 dc van !!! Some Mk1 and t2 ant3 gear in my stash,,,
