Page 7 of 15 FirstFirst ... 56789 ... LastLast
Results 61 to 70 of 141
Thread: Adolf the Golf (VR6 Racecar)
  1. #61
    Aug 2006
    Melbourne VIC
    Quote Originally Posted by Smeeeb View Post
    I have grey vr shell in my garage if you need body panels.
    Perfect!
  2. #62
    Sep 2009
    I guess that is the big difference between putting a vr6 on megasquirt and an e30, theres heaps of people running e30s on megasquirt in Australia and I know a couple local guys running it on the same motor as mine, so if I run into trouble I have people to ask, but its quite the opposite with the VW's, I guess you would be on your own except for support on forums from people in the US etc... Its definintely a big learning curve, learn a lot about electronics and how lots of little bits of the engine you've never even thought about work. Once you have it set up though the possibilitys are endless, you're no longer running a generic tune and can squeeze out every horsepower the engine is capable of making with your exact modifications, and if you do more modifications or even swap engines, you simply just plug in the laptop and tune it again
    But yeah, a stock vr6 weighing in at <1000kg with a good suspension set up will be more than enough to have a great time with and learn to race with. I'd be spending money on things to make it handle nice before looking for more power, a good set of coil overs would be the first thing I'd buy (I know you've got the racelands, but theyre not exactly known for doing anything more than getting you low on the cheap, which isn't what you actually want on the track really) followed by sway bars, bushings etc and a set of wheels with some nice sticky tyres. Good brakes are also very important. Strip it out and get the weight down, set it up to take corners and stop like a boss, and then start the engine work. Cornering nicely is much more fun than just pulling hard down the straights
  3. #63
    Eltham, Victoria
    Quote Originally Posted by ben j View Post
    cornering nicely is much more fun than just pulling hard down the straights
    truth!
  4. #64
    Aug 2012
    Kangaroo Valley, NSW
    Simon pm me your phone number and ill call you when dad gets home with keys to the shed and we figure what's good and what's not.
  5. #65
    Mar 2009
    Wagga Wagga
    Quote Originally Posted by Ben J View Post
    Thanks for the tips, Ben!
    This quote is debateable though
  6. #66
    Mar 2009
    Wagga Wagga
  7. #67
    Mar 2009
    Wagga Wagga
    Another long day.
    First I would like to thank my parents, my mate Brad, and Jordan (Smeeeb) and his dad. Top blokes, thanks for the help!
    My mate Brad and I took a 4 hour drive to Kangaroo Valley to pick up some parts, off Smeeeb.
    Now this would usually be fine, except one of those parts was a windscreen that we had to remove. Never having removed a windscreen before, we began praying to Lord Goku. For anyone who doesn't know how this is done: You need to saw through the glue holding the windscreen to the body. Easier said then done. Luckily, I had taken a trip to Obrian's Windscreens the day before and picked up some wire and got a few pointers off a very helpful staff member. After a solid 2 hours of sawing through glue, snapping wire, swearing and cutting ourselves, we were able to remove the windscreen with no cracks! Jordan's dad kindly removed the rest of the panels we needed!
    So we ended up picking up:
    Windscreen
    Bonnet
    Front Bumper
    Front Grill
    Front Drivers side fender
    Front passenger side door
    Rear hatch
    VDO Instrument Cluster
    Glove-box
    Headlights
    Taillights
    Few misc. pieces (Pretty much everything we need is sorted now!)
    4 hour drive home, unload the parts, and Zale and myself stripped most of the racecar!
  8. #68
    Aug 2012
    Quote Originally Posted by trickysimon View Post
    Hey that's my garage!
  9. #69
    Aug 2006
    Melbourne VIC
    Good work fella's.
  10. #70
    Jun 2007
    Eastern Suburbs Melbourne
    Good work!
    Are you going to skin doors, perspex windows or anything at this stage as well?
    i like volkswagens
