Results 1 to 10 of 17
Thread: Adjusting headlights on a VR6
    Jun 2007
    Canberra
    Anyone got any tips on adjusting the headlights on my 1994 VR6? i was driving in a foggy canberra night on monday and could see the left light was pointing off accross the beam from the right light... explains why i cant see so much in front of me when i'm driving
    i see those two while barrel-type things which will move the lights around but i just can't seem to get them pointed where i want them. is it best to park nose-in to a wall and adjust them there etc?
    Jan 2007
    Quakers Hill, Sydney
    I park in front of my garage with the door down
    Seems to work OK
    Mark
    Camden, Sydney
    Make sure that the reflector isn`t loose inside the housing, very common on Mk3s.
    If all is good, then simply adjust as normal.
    Nov 2006
    Central Coast, NSW
    yeh those wheels do the trick - one does vertical, the other horizontal. if they don't align like you want them to, take the black cover off at the back and try adjusting the inner lens.
    this next step will make sure the lights are correctly (and legally) aligned.
    you will need:
    tape measure
    chalk or tape
    1. measure the distance between the centre of each of your headlights.
    2. measure the distance from the ground to the centre of you headlights.
    3. mark the measurements up on the wall using the chalk/tape making it look something like so:
    4. park your car about 2 meters away from the wall and position your lights accordingly.
    5. drive forward about a metre, test that they are still aligned
    6. reverse to about 3 metres away and check again.
    Sep 2006
    Australia?
    How do you stop the reflector from moving around mines a bit wobbly
    Nov 2006
    Central Coast, NSW
    more to my last post:
    if you want the lights adjusted legally, you will need to do a few calculations using a scientific calculator...
    headlights in australia are supposed to be dipped by about 1.2 degrees so to work it out, you will need to put some of the previous measurements into the following formula:
    h = light height
    d = distance from wall
    x = distance below light height (h)
    y = diagonal distance from light to wall
    c = correct light height
    Nov 2006
    Central Coast, NSW
    Quote Originally Posted by Mk3vr6 View Post
    same here, i don't think you can. I'm going to buy some new lights sooner or later, when I do, I'll upload pics if I find a way to fix it.
    I just used electrical tape as a temporary fix.
    Sep 2006
    Australia?
    On a slightly off note, what are the parker lights???
    There not wedge based there got 2 pronks and its like a twisty thing. I tried to install some light bulbs yesterday and they weren't working.
    I know have PHILIPS Crystalvision lights with amber parkers looks gya and crap
    Aug 2006
    Skye, Victoria
    that is your parkers small wedge globe, they come on in your first click on the headlight switch.
    Sep 2006
    Australia?
    Quote Originally Posted by BlackVr6ix View Post
    Yeah but there not actually wedge mine are like a twist you can see them on your actual headlight. I was like WTF.
