321615301D - front vented disk 256mm
357698151A - front pads
357615601 - disk rear 226mm
1H0698451D - pads rear
google "VAGCAT", signup and poke around, you will learn valuable things.
heya guys,
only got my car few weeks ago, its overdue for brake pad and disks,
was wondering if anyone had some part numbers for the 95 gl pads + disks
no one can seem to help me at burson, gsl etc
any help would be great
Chris
'98 Mk3 Cabriolet 2.0 8V
'99 A4 Quattro 1.8T
Chris,
The problem you've got is that 95 is a cross over year for the 2.0L, and you can't know for sure without physically checking what you've got. The reason neither ourselves or anybody else can help is because to tell you what you've got is taking a wild stab in the dark, and if wrong, causes more issues than going to the effort of finding out what you've got in the first place.
You're front pads can either be:
DB1325 - http://www.atap.com.au/atap/ATAPWEBD...%20(Small).jpg
or
DB1400 - http://www.atap.com.au/atap/ATAPWEBD...%20(Small).jpg
You're rear pads will be:
DB1192 - http://www.atap.com.au/atap/ATAPWEBD...%20(Small).jpg
Rotors, it should have 256mm x 20mm vented rotors on the front, and 226mm by 10mm solid rotors on the rear.
Std rotors are $49 each for the front, and $55 each for the rear.
Pads, find out which front you've got first, and what you're using the car for, and we'll price up a few options on pads.
Regards,
Greg
GSL RallySport 1300 884 836
Sick of paying too much for performance brake pads? Want high performance with low rotor wear?
QFM Performance Pads
bah... I'll just price up the pads now! Got 3 mains levels for use in an ordinary street car...
Ok, going cheap and nasty RDA:
DB1400 $35
DB1325 $33
DB1192 $33
Cheap, but good quality, low dust QFM Super X:
DB1400 $49
DB1325 $49
DB1192 $49
Very high quality, european made TRW Remsa pads:
DB1400 $90
DB1325 $99
DB1192 $69
If you've got time on your side (which by the sounds of it you don't), and wanted both a performance street pad and low dust, then we could get the QFM HPX (Bendix Ultimate equivalent, but very low dust and rotor wear) manufactured. Would be $79 per axle set, and about 3-5 weeks wait.
Regards,
Greg
