Page 3 of 3 FirstFirst 123
Results 21 to 28 of 28
Thread: 94 Golf MK3 Lost Key!
  1. #21
    Mar 2014
    Bundoora, Victoria
    My spare key had a piece of plastic attached to it which I accidentally cut off and threw away. What was it for?
    I know that new Ford's come with a plastic identifier of some sort attached to the spare key.
  2. #22
    Aug 2011
    so i'm still looking to get my key duplicated, any idea of a place in Sydney that can do this?
    i THINK i have an immobiliser, i tried to take apart the key but it didn't want to budge and i was worried about breaking it...
    any idea how much it would cost?
    Thanks
    2010 Jetta 125TDi DSG
    1994 Golf VR6 Manual
  3. #23
    May 2010
    Quote Originally Posted by stefcio007 View Post
    Probably the master key. My wife's Mk5 R32 came with it and it's still on MY key ring. Can't remember if it has notches or just a number printed on it.
    Mk IV Golf GTI - BMP - GIAC chip, R32 wheels, KW coilovers, rear swaybar.
    Originally Posted by JoeVR
    I've never been a big fan of rotors, or really Japanese cars in general, so my choice would have to be..... an RX-8.
  4. #24
    Mar 2014
    Bundoora, Victoria
    I assume the plastic really doesn't serve much purpose? Other than visually identifying that it's a master key?
    Past - '95 VW Golf MK3 VR6
  5. #25
    May 2010
    Correct. Am home now and just checked ours. Just has a label with printed number.
  6. #26
    Nov 2015
    I remember reading somewhere that the plastic tag with the printed number on it is a key ID, which you can quote to VW and they can create a duplicate key based on that number alone.
    1997 Golf CL, 2011 Caddy Life TDI, 2007 Golf TDI, 1996 Vento GL (red), 2008 Skoda Octavia TDI
    1996 Vento GL (white) - RIP
  7. #27
    The tag would of been the mechanical key code, this code relates to the cuts on the key to work the lock. The dealer does not need this as they keep all this information on record, if you were ever to get a key from them all they would need is the VIN and from that the key will be cut to suit your locks and have all the relevant coding needed for it to be programmed to your car.
  8. #28
    Aug 2011
    new key has now been coded and cut!
    in the end got it from Mister Minit at QVB in Syd.
    Key, cutting and coding came to a total of $100 and it works perfectly
