LOL less talking more listening for you Houso. It took a lot longer than that to build the 20VT Ibiza. That was with a complete donor car which was already running aftermarket fuel computer, so really just had to be plug and play.
That took me, an experienced industry professional a fair while. To those of you talking hot air and theorising about doing such a job at home. Good Luck.
It still costs lots of money wheteher I do it or you do it at home.
I can do it faster as I have a workshop and facilities and knowledge, but you will have lots of dramas to overcome and that will cost you time and money.
Jay Jay. There were Turbo Technics conversions back in the day which used the kjet setup. And yes you can push more fuel into a NA setup using Volvoparts. Early Saabs also used Kjet, but I never had much luck getting those parts to work on VW. Volvos yes.
Audi 200T used kjet, Turbo and 5cylinder. Look it up. In the US they cut the 5th cylinder part off the manifold and use only 4 of the lines and bolt it onto your 4cylinder motor.
Easiest upgrade for your car Jay Jay would be a 16v, as yours is one of the few Mk2 running Kjet. Plug and Play for you mate
