Results 1 to 7 of 7
Thread: 2 Litre Pressure Plate Stretch Bolts
    Aug 2008
    Mid North Coast NSW
    Getting conflicting information about the requirement to replace the bolts between the pressure plate & the crankshaft.......
    Some say they are stretch bolts & should be replaced every time.......some say they do not need replacing......
    so which is it?
    And what about the pressure plate to flywheel bolts? from what I can determine they are Ok and don't need to be replaced.
    Thanks for your help.
    Calling NSW Mid North Coast VW Enthusiasts - Click Below
    Mid North Coast Dub Club
    Apr 2013
    Every clutch kit i have bought, (i've only bought two) has come with replacement bolts for everything. In your case, if you're sourcing everything separately i'd just get new bolts. At least if there are problems after the install you know it won't be because of loose bolts. Just my 2c
    Red 9N3 Polo GTI (sold)
    Mk3 3dr Vr6 Project
    Thought they were replacement, I did mine anyway.
    Cheap enough just to do it for piece of mind
    Aug 2008
    Mid North Coast NSW
    where'd ya get em?
    Tooleys, where I'm probably getting the rest of the bits from, don't sell them as they say they don't need to be done.
    Any leads would be appreciated.
    Brendan
    Got mine from ecs
    Apr 2013
    ECS for me as well
    Tooleys is pretty good for most service parts, but stuff like bolts I've found the stealership is the best option locally.
    Aug 2008
    Mid North Coast NSW
    Thanks Gents, I'll try the nearest VW Dealer first, as shipping from ECS is $50 which I may be able to wear if I had reason or $$$ to order a few other bits from them, but that's not on the cards at the moment.
    Thanks again for your help.
