Results 1 to 10 of 18
Thread: 12V VR6 oil preferece
    Sep 2010
    Southern Highlands NSW
    With the good old mk3 VR6 being 20 years old and a lot of them that have reset the odo at 300k, with the motors starting to suffer from wear and worn valve stems and what not im curious to know what brand and type of oil you guys are running?
    All the VR6s ive owned its been either Penrite HPR10 10w50 or Nulon Full Syn 10w40 (Hi Tech Fast Flowing) that they seem to run best on.
    Polo GTI
    T-Roc R
    Tiguan R
    Tiguan 162 Allspace Wolfsburg
    Mar 2011
    Bunvegas, Western Australia
    Ive been running Royal Purple 10w40 and have been extremely impressed so far
    1976 VW Golf "Swallowtail" - Rallye Red (long term resto)
    2009 Pirelli GTI - Stg3 killer
    2009 R36 Passat - Daily baller
    You take corners on three wheels, and V8's can't catch you.
    Dec 2008
    Sydney/Canberra
    10W40.
    Doesn't have to be anything flash.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Mar 2014
    Bundoora, Victoria
    Penrite 15W60...apparently I am doing it wrong.
    Another question, how often do you change?
    Past - '95 VW Golf MK3 VR6
    Dec 2008
    Sydney/Canberra
    Every 10K max.
    '01 Beetle 2.0
    Sep 2010
    definetly no more then 10K
    15w60 is quite a high viscosity what is the reason you use this oil? consumption problems?
    Polo GTI
    T-Roc R
    Tiguan R
    Mar 2014
    Bundoora, Victoria
    Quote Originally Posted by VR28LT View Post
    It's what my uncle put in it when he showed me how to change the oil and oil filter. And I've forever been stuck in the loop of; have some oil left over, but not enough, buy same oil, now have some oil left over...
    Apart from following recommendations on here, what are the benefits to switching what oil I use? I assume low viscosity means the engine works less so it burns less?
    Jun 2011
    5w30 in mine. Change every 3,000km filter every second oil change. It's cheap enough not to.
    Reason being, i want oil in my lifters when bouncing off 7.5k rpm
    Erskineville, NSW
    Quote Originally Posted by stefcio007 View Post
    You can mix oils - it's no big deal
    Mar 2014
    Bundoora, Victoria
    It isn't? Well that makes things a whole lot easier. Guess I wanted to be safe than sorry.
