Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: 1.8t
    Feb 2008
    perth
    1.8t
    has any one here or no of any one that has put a 1.8 t out of a mk4 or a audi in a mk3 if so how hard would it be.
    It would be easiest to put in a VR6, as that has a more suitable gearbox to start with. I have a std A3 gearbox/linkage and a heap of other useful parts for under the bonnet if you wanted to convert a 4 pot.
    Don't jump on board with the stand alone management argument. You can run it with the OE stuff.
    I have an AGU engine loom and ECU etc in my garage. I could have it tuned for you, if you wanted it.
    Feb 2008
    perth
    i should have had a look bfor i asked the is a little bit on here already about this topic sorry
    Quote Originally Posted by mk3 gti View Post
    There's a lad in WA doing an S3 conversion into a MK2 which isn't so far removed from what you're asking.
    A front cut is what you want, with the electrics intact.
    Feb 2008
    perth
    yes i no the bloke he did work at golf wagon i think that the way i should go ill try find a half cut befor i start planing to far ahead
    Jul 2007
    Canberra
    Personally I don't see the point. VR6=128kw, 1.8T (even chipped) is what 148kw? For the price you're better off supercharging a VR6 and getting 190-ish kw and monstrous Torque. Or turbo a VR6 for even higher gains for probably about the same coin.
    Forever blowing bubbles.
    May 2009
    Quote Originally Posted by Pullstarter View Post
    Maybe because the 1.8t is a newer engine, more reliable, better on fuel lighter? Just some of the reasons I would consider it
    Jul 2007
    Rowville Melbourne
    not to mention the head flows better.
    free flowing 5 valves vs. choking 2 valves per cylinder.
    that being said, i do have a vr6... haha
    -steve
    Jul 2007
    Canberra
    Fair enough to all that BUT if you're after a significant power increase the 1.8T is a snoozer unless you spend big $$ on it on top of the already spendy conversion.
    Jul 2007
    Rowville Melbourne
    i reckon thats probaly true. 1.8t is a wicked engine. but so is the vr6
    traction might be a little harder to get a hold of with the 1.8t being such a light engine compared with the VR. that being said, spend less money and get the same power with the vr and still have trouble getting traction...
    -steve
