Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: won't idle! URGENT!
    Oakleigh VIC
    Like i said the other day, check that idle air bleed. They have a habbit of not staying in the right spot. wind it all the way it and remember how many turns out it was. next time you have trouble, wind it all the way in, counting the turns and see if it has wound in or out..
    Yep, I had the same thing happen and all it takes is a 2cent O ring to fix it. I've got heaps of them Stu.
    I can set that CO% for you one day if you'd like Stu.
    Pete
    Quote Originally Posted by thestu View Post
    the aux air valve, cold start injector and the warm up reg are not wired up. but i did have this motor running previously in my 4 door beautifully without these things also hooked up.
    I'm lost it may run but can't be 'beautifully'
    Oakleigh VIC
    Quote Originally Posted by RedMk2Gti View Post
    The electrics only assist in cold start, the motor will run OK without them. It might take a bit longer for the WUR & aux air valve to come up to temp but they will eventually and it will start OK without the 5th injector.
    (I accidentaly forgot to plug the loom in once and ran mine this way for two weeks, didn't actually make that much of a difference.)
    Pete
    Eastern suburbs of Melb
    it did. something must have changed...
    Pete
    ohh brilliant that would be wonderful pete!
    Oakleigh VIC
    I got a pack of assorted tiny O rings from Bunnings for about $2 there must be a zillion of the little fk'ers in the box
    Pete
    Pete
    haha wicked cool. i will make a trip up one day soon! wait...what are you doing today? my rents go to qld tomoz with the car! :O
    Oakleigh VIC
    Bit busy tonight sorry. How's that RWC going?
    Pete
    Camden, Sydney
    I reckon a vacuum leak. If not the bleed screw, maybe one of the rubber joints in the system is expanding when hot and creating a leak.
    It could well be the idle screw though, I had one fall out once and it ran with a mad sucking noise, but would obviously never idle.
    Aug 2007
    Idle screw is a classic , man spray around when its playing up and watch and listen for the rev change and you have the spot
    Alba European
    Pete
    all good. rwc terrible. they broke my linkages then called me and said its undrivable...wtf! then they just made up bull****. i said to him the idle is high so adjust it...and he was a wanker and didn't. oh well i am going to fix some more stuff and dean from volkspower is going to do it for me next week so i have a few days to replace the g-box and some other stuff
    Quote Originally Posted by Jmac View Post
    yeh im gunna try that but i am fairly confident its the screw...
