Results 1 to 9 of 9
Thread: Width
    Nov 2007
    Width
    What is the maximum wheel width under a MK2 Golf without scrubbing out or using stretch tyres ?
    Can anyone pass on some knowledge ?
    Thanks
    Sep 2007
    Just spent sooo long working this out...
    Firstly, front or rear, what suspension, what guards, arch spats, what kind of look?
    perhaps post up a pic from the net of what kind of position you want your wheel to stick out, then should be able to go from there.
    87' MK2 GTI
    13' MK7 TDI
    Gold Coast
    I'd say probably maybe a 7" depends on ride height & tyres
    Nov 2007
    Do you know tommymacs old MK2 DUB551 ??
    Quote Originally Posted by jayjay View Post
    ---------- Post added 08-11-2011 at 11:01 PM ---------- Previous post was 07-11-2011 at 05:55 PM ----------
    This would be nice !!!
    Gold Coast
    EDIT: They are;
    BBS RS 8x15 with 185/45 tyres
    Sep 2007
    pretty much - rules are:
    8" front, 9" back is what guard room permits. offsets need to change if you go wide track (vr6 arms etc)
    rules can be bent/broken given an angle grinder/welding skills/patience/apathy toward tyre and guard conditions.
    for equal stretch, go 8s all round - easy to get tyre sizes. staggered sets means rotating your tyres is quite difficult.
    Offsets:
    anywhere between 15 and 35 depending on spacers/coilovers/suspension. choose wheels or suspension first!!
    The mk2 stance thread on vortex has sooo much info by the way. with photos. with specs! check it out
    87' MK2 GTI
    13' MK7 TDI
    Nov 2007
    WOW !!!
    You know your stuff.
    Thanks
    ---------- Post added at 08:18 PM ---------- Previous post was at 08:17 PM ----------
    Thanks mate
    Well spotted from that pic.
    Quote Originally Posted by walshydub View Post
    EDIT: They are;
    ---------- Post added 11-11-2011 at 03:43 PM ---------- Previous post was 10-11-2011 at 08:18 PM ----------
    These should fit ????
    Gold Coast
    With the right size adaptors, yes they will. What offset are they?
    Mar 2010
    perth, W.A
    Porche d90's should fit easy with the correct adapters as stated,they're somewhere around 52 from memory so 25 or 30 mm adapter wold be good depending on tyre size... Are they the staggered set?
