Results 1 to 10 of 12
Thread: whinning noise from engine bay
    Sep 2008
    melbourne/woopwoop
    hey guys im gettin a whinning noise coming from the egine bay when going 100km/h onwards
    any ideas what this could be? noisey belt???
    Feb 2007
    Spray a bit of WD40 on the belts and see if to goes away. Dont spray to much because it might cause the belts to slip. I usaly spray it on while the engine is running and stop spraying when the noise goes away. There is also a lub stick you can buy for belts, its like $2 from an auto store.
    Although, i dont think that its your belts making the sound, as you say its only happening over 100km/h. Taking a guess it could be your gear box or something that is just making the noise because of the air rushing through.
    MK1 GLS 3door
    A4 B7 2.0T
    Jul 2009
    Ringwood,Victoria
    I used to get a whining noise coming from the passenger seat,
    divorce fixed it,
    Good luck finding your noise.
    "That's what she said"
    Feb 2007
    Quote Originally Posted by FACT HUNTer View Post
    divorce fixed it,
    LOL!!!
    MK1 GLS 3door
    A4 B7 2.0T
    Sep 2008
    melbourne/woopwoop
    yeah i think it is air rushing through the gear box,
    and LOL!
    also noise usually happens at night when really cold and driving, not on idle, rev it out a bit and the noise disappears
    Feb 2007
    Quote Originally Posted by koztek55 View Post
    and LOL!
    I didnt mean air rushing through the box, i ment air rushing through anything an creating a sound. Could be a bit of plastic or something.
    Is the sound in every gear and would you be able to describe the sound. Does it get louder or faster as you rev?
    MK1 GLS 3door
    A4 B7 2.0T
    Feb 2007
    Haha Kosta? Didnt realise it was you. Tellin you shiz you already know.
    MK1 GLS 3door
    A4 B7 2.0T
    Jun 2007
    Eastern Suburbs Melbourne
    not the supercharger is it??
    I would suspect noisy timing belt (ie done up too tight) but that you notice all the time, in every gear, and (obviously) it's related to engine speed.
    try and figure out if the noise gets louder as you go faster (speed) or as the engine speed increases (rpm)
    i like volkswagens
    Apr 2009
    mate its the belts just lube them up a little
    The Mk2 GTI Baby
    Sep 2007
    if your belt set up is original, it should be running v-belts yes?
    there's a tensioner bracket on the alternator, which requires a 13mm spanner and a big! (26mm ?) to tighten. it sounds like your belts are slipping. if you nip them up it might do the trick.
    does it do this when it's really rainy as well? if yes, then the belt is slipping on the alternator pulley wheel.
    87' MK2 GTI
    13' MK7 TDI
