Results 1 to 4 of 4
Thread: wheel bearing
    Dec 2008
    Launceston, Tasmania
    wheel bearing
    Hey guys,
    the golf has started to hum and vibrate when i turn left at speeds over 40... Sounds like a RHF wheelbearing doesnt it? Not too sure how they sound on golfs as i have more to do with fords... Just put in a new p/s pump and the belt is tight... Let me know what you guys think!
    Thanks, Stefan
    ----[ Finished the search for a mk2 GTI]----
    1990 Golf Mk2 GTI
    276* cam
    2 1/4 in straight through exhaust
    H&R springs on KYB shocks
    Could be, make sure the hub nut is tight too. If it's slack, chances are it did the bearing in. 30mm socket and 2 foot bar.
    Sep 2011
    Go no bigger than a two foot bar! I just replaced the outer CV, torqued up the hub nut, and stripped the cv thread tightening it up too much. . Off to get another outer CV.
    Not so tight this time.
    1990 MK2 Golf GTI
    bardon
    +1 YES... I thought I had bearing problems and the wheel hub nuts were loose.
