Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: What heads fit a 2e 2 litre bottom end?
    With a bit of luck I'll get a 91 MK2 by the end of the month and it currently has a 2e bottom end under the standard head. Long term plan is to convert it to run on LPG because I do over 800 k's a week and gas is cheap. Running a gas carby also makes it easier to fix if I break down.
    Since it will be running on gas I don't have to worry about any of the injection or engine management systems so swapping to a 16v head should be an easy job.
    What heads suit the 2e block, give better performance and don't cost the earth?
    Paul
    Paul
    16V heads don't bolt straight on a 2E. All 1800 8V heads will go on it.
    you beat me to it Gav
    Velly
    '91 2.0 8v GTI
    Quote Originally Posted by DubSteve View Post
    I have wood thinking about you
    I'll stick to exhaust and cam then. Maybe bump the compression to 14:1 if I make it dedicated LPG.
    Feb 2009
    Please Enter Location
    16v heads do bolt on to a 2e block,std 2e pistons don't have the valve recess but they do bolt on.
    Quote Originally Posted by Stanton View Post
    Are you sure? do all the waterways and oil ways line up?
    Pic's or it didnt happen
    Velly
    '91 2.0 8v GTI
    ok, just found this but the thread is very old.
    Velly
    '91 2.0 8v GTI
    Feb 2009
    Its just basic knowledge, and golly gee they even use the same head gasket.
    Perth. WA
    To run a 16 V head on a 2E you will need to change the intermediate shaft, oil pump, sprockets. Compression will be crap with the 2E pistons and you will need to cut notches in the pistons. You could use ABF pistons if you can find any with the correct diameter grading.
    Loads simpler to just bolt up a 1.8 head then go from that...
    Lots of MK 1 Scirocco's...
    Cheers,
    Grant...
    Definitely not worth the trouble using the 2e block as a starting point.
    What's the trick to build a 2.2 litre?
