Results 1 to 7 of 7
Thread: what duration should i go with my cam any ideas?
    Dec 2008
    melbourne
    Jun 2007
    Eastern Suburbs Melbourne
    what car do you have?
    what engine?
    what's it's condition?
    whats the target Hp?
    what work has the engine got done?
    etc etc. need much more info fella.
    i like volkswagens
    Dec 2008
    melbourne
    its a 1992 mk2 gti 8v with 113000 kms on it its stock as a rock aside from a exhaust system i will be doing a full overhaul on the head eg bigger valves port and polish. im wanting more mid range power.
    Jun 2007
    are you chasing big numbers, or just hoping for some more power?
    are they +1 oversize or massively oversize?
    Something around a 268/270 is a reasonably mild cam, should give a nice bit of poke without compromising smooth engine idle etc.
    i like volkswagens
    Feb 2007
    268 cam, full exhaust, 2L bottom end and 38/40 valves gives about 150hp at the fly. After 140hp you will need a heavy duty clutch. There is a thread about mk2 2L 8v tuning on ClubGTI, also dyno sheets and some times slips.
    MK1 GLS 3door
    A4 B7 2.0T
    Sep 2007
    there's actually a plethora of ways to modify an 8v. purely depends on budget and goals.
    tell us what you're after and then search for it on here or vortex of club gti, and then when you cant find results we'll tell you.
    a 270 autotech or techtonics tuning 276. port/polish, (you could look for a k-jet mk2 gti head which has much bigger valves to begin with) and a bit of a skim to bump compression and you'll have a quick little golf with lots of mid-range
    87' MK2 GTI
    13' MK7 TDI
    Dec 2008
    melbourne
    ill probably have about 4gs to play with after i sell my polo so all that ill be putting into the motor
