Results 1 to 10 of 13
Thread: Watercooling question
    Just a quick one to run by u guys, ive noticed my GTI has run pretty cool since i bought it...its always hovering at about just past quarter on temp.gauge...isnt it supposed to be getting to the half (operating temp?) Is my thermo stuffed?
    Aug 2007
    Wink
    Should run at 90+ mate. thermostat starts opening at 82 degrees, it sounds like its a gonna mate. Address it quickly mate as you will dilute your oil with fuel running cool and not getting to operating temp is not good in the long run.
    Good luck champ
    Alba European
    Apr 2006
    Asaka-shi Saitama Japan (from Tassie)
    yea, too cool means the water is flowing too quick.
    sounds like the thermostat to me.
    Mine runs between half and 3/4.
    Cheers, Benny
    www.axesent.com.au
    Aug 2005
    Prahran, Vic
    yeh sounds like its stuck open. my temp sits smack on half most of the time.
    Camden, Sydney
    Maybe no thermostat in there at all.
    Aug 2007
    Golf Loon yeah i was goin to suggest that wouldnt be the first time hey! but i thought by the sounds it had just started to read low.
    Alba European
    Oct 2005
    Dandenong North, Vic
    Are you getting any heat when the heater lever is on inside ?
    I remember my temps were just over a 1/4 and when the cars stationary for a while it would creep up to 1/2 way when the cooling fan switches on and down it goes back to just over a 1/4.
    MK2 GTI G60
    Actually i dont put my heater on because for some reason she starts choking on idle whatever the temperature...a quick blip of the throttle cures it and she goes back to 900rpm
    Apr 2008
    Bringing up an old thread.
    My GTI when in stop start traffic gets to the first 1/4 on the gauge and when driving at a constant speed it goes down to just above the "cold" section
    That's not right is it?
    Btw where should the needle be for normal operating temp? The middle?
    Jun 2007
    Eastern Suburbs Melbourne
    I say that sounds pretty similar to the op Ben.
    thermostat issue. Should be half and above in traffic. Lower on the fwy of course.
    You can take the thermo and check it still works by heating it up with a heat gun/ hair dryer kinda thing. It's should "pop" once it heats up enough
    HTH
    i like volkswagens
