Results 1 to 10 of 17
Thread: VWwA Used Car Guides Golf GTI (Type 1G) 1990-1991
    Jan 2007
    South Australia
    Question VWwA Used Car Guides Golf GTI (Type 1G) 1990-1991
    1990-1991 Golf GTI
    If you have owned or own one of the models above please state your experience with the Golf, negatives and positives
    Also fill in the below blanks
    example
    Model: Golf GTI
    Engine: 1.8 8V 77kW
    Year: 1990
    Any Problems ?: tyres fell off etc
    - Ben
    1961 Karmann Ghia Coupé - 1993 Golf Cabriolet - 2006 Golf Comfortline 1.9L TDI
    2008 Jetta 2.0L FSI
    Penrith, NSW
    Model: Golf GTI
    Engine: 1.8 8V 77kW
    Year: 1991 (188,000kms)
    Any Problems:
    - Service History indicates power steering pump replaced twice, rack once and i think something is up with it again, lots of noise when under more stress (lower speed)
    - Gearbox crunches from 1st to 2nd and has some serious transmission whine, has 188,000kms on it and will be replaced shortly though. (Don't sell that Recon Box Golf Loon!! )
    - Rocker Cover Oil Leak - Gasket getting replaced this weekend
    Positives:
    - Engine still feels very solid and has more go in it than you expect for an engine rated @ 77kw at manufacturing time. Especially as you move up the rev range.
    - Interior has held up fairly well.
    - Handles like its on Rails, even with the dodgy tyres i have on at the moment.
    (Is this the sort of thing your looking for?? My Service history is pretty good (with reciepts!) but has gaps in it recently, so this is what i know)
    1986 MkII Golf GTI 16V (Sold), 2005 MkV Golf GTI (Sold), 2007 Polo GTI (Sold), 2011 Polo 66TDI (Selling), 2012 Passat 125 TDI Bluemotion, 2013 Scirocco R (Due October!)
    Apr 2006
    Hobart,Tas
    I had a 87 3 door GTi, black with a 2E motor fitted. The thing flew at the time and handled fantastically. I fitted Koni Sports and lower springs. I did a couplke of trackdays in it but my greatest moment was finishing 6th outright in "The Classic Challenge" in NW Tasmania. I loved that car. Problems were only 3 valve stem seals fitted when I first bought it and later I did the head gasket. Otherwise zilch in the way of worries with it.
    It is now 86GTIs Golf.
    Jun 2006
    Thornbury, Vic
    1990-1991 Golf GTI
    Model: Golf GTI
    Engine: 1.8 8V 77kW
    Year first rego: 1992
    Kms: 235000
    Any Problems?: Not many. Has been a super reliable car. Starts first time always. I've owned it since 2001 and done almost 100000kms in it and the only time it didn't get me where I wanted to go was when the clutch cable snapped on the way to work a couple of years ago.
    Other probs I've had fixed over the years:
    Gearbox linkages
    leaking coolant
    cv joints
    General wear & tear, hoses replaced, cam belt, rocker cover gasket etc.
    Positives:
    Great fun car to drive, handles really well
    Economical
    Reliable
    Hard wearing
    Looks great (when clean )
    Negatives:
    Door handles hard to open (especially back doors)
    Could do with a bit more power
    Drivers seat badly designed, bolster wears out too quickly
    May 2006
    byron bay area
    1990 mk2 gti report
    this unit has done 280K & has a good service history
    it goes like a steam train when on the open hwy especially up hills giving fuel usage of 6.8L per 100km on @100kph
    has never leaked water & no rust what so ever
    it has koni sport shocks & springs, therefor handle extra well
    has the capacity to leave much higher powered cars up hills & on flats for dead
    build quality is top of the range
    interior stands up well except for the dash board
    as far as I know it has the original wheel bearings & clutch ect
    a good all round car
    good value for your $$$ & is compatable for many upgrades
    the power steeing pump & rack have been renewed
    cam belt
    very low power down low in 1st gear, so not good for traffic light GP's
    it is very hard to knock this model except fot the low power off the mark
    May 2006
    Just returned from a holiday. 3000 kms in a two weeks. Average 7.5 litres per hundred included hundreds of kms in the bush sitting at 150-160. Nothing fell off. Zero oil consumption. Goes like stink again.
    I no longer own this :-
    1990-1991 Golf GTI
    Model: Golf GTI
    Engine: 1.8 8V 77kW
    Kms: 165000
    Any Problems?: Plenty of oil leak, p/s rack, transmission, Heater not working, head gasket problem. Electric mirror not working, ex-owner didn't look after it -> paint work fade badly
    Spent big $$ to fix :
    Shift linkages
    Almost everything in the cooling system.
    2 front legs
    Replace door handles
    Replace p/s pump and hose
    Replace cam belt
    Regas air-cond
    Positives:
    Classic look - IMO best Golf
    Excellent rust proof
    Economical
    Not exciting in power, but in handling
    Negatives:
    North Sydney
    Model: Golf GTI
    Engine: 1.8 8V (I always thought it was 108kw but must be wrong)
    Kms: 190,000
    Any Problems?: I have had the car for almost 2 years . In this time the only problem I have had has been a leaking radiator hose, and small problem with the revs jumping about when stationary that was inexpensive to get fixed. Its reliable and always starts first go. I have a new cam shaft and cam gear in mine which I think makes the car always want to be going faster than 20kms, so it will jerk about a bit when going slow and giving the car a bit of petrol. Car is zippy, and on the highway, you will get up all hills at the speedlimit. In my opinion the mark 2 is the sexiest hatchback out there.
    The only negative in mine is the a/c doesn't produce enough air. The highest setting doesn't blow out enough, so the car will take 20+ mins to get cool, or you just put the windows down.
    Model: Golf
    Engine: 1.8 8V
    Year: 1988
    Any Problems ?:
    Only a couple of minor prob's which were one waterpump, replaced all the cambelt side seal's, gear shift ball repair & one clutch.
    Not too bad for over 220K.
    Just starting to have some very minor rust issue's which will be repaired very soon.
    Oct 2005
    Dandenong North, Vic
    Model:Golf GTI
    Engine: was a 1.8 8V 77kW Engine Code RV,
    Now PG 118KW G60
    Year:
    Built 1990, 1st registration 1992
    KM: 110,000
    I have my MK2 GTI since new, purchased in 1992 to date.
    What I have experienced over the life of it so far:
    - When new, under side of passenger trim was originally ripped
    - Gearbox oil started leaking after 2nd year making LHS wheel very oily
    - Oil leaking slightly all around rock cover
    - Reverse and 1st gear would sometimes be impossible to shift into
    - Headlining, passenger side handle grip cracking
    - Annoying creaks and rattles developed from LHS rear quater
    - After a warm engine it used to idle rough and nearly stall until revved up and idle would become stable (common ISV problem)
    - Rear door handle lever snapped
    - Once stainless exhaust was fitted (Cat back) a squeak developed during gear changes from movement, exhaust manifold to downpipe coupling
    - Replaced ecu chip, become more responsive low down
    - Paint seems to chip really easily
    - A/C cooling never lasts over 2 years after R12 to R134 refrigerant change over
    Good points:
    - When I first got it, it handled like a cart but gradually softened over time.
    - Always drives straight.
    - Always starts on first turn of key.
    - Excellent fuel economy, managed 650-700km full tank trip
    - Haven’t had any heating issues yet with a leaky core
    - Power was noticeably better on cold mornings
    - Always pulled well low down in rev range (due to rechip)
    - Never had any probs with power steering, like the sound.
    - All original glass and lights, not yet replaced.
    - No body rust apart from minor rust migrating from inner rubber door seal joins (contain a steel clip) which is clipped to the inner door openings to body
    - IMO, very well built.
    - Wide range of VAG engines can possibly be made to fit to liking
    MK2 GTI G60
