Results 1 to 5 of 5
Thread: VW Sealing Pastes
    Oct 2005
    Dandenong North, Vic
    VW Sealing Pastes
    Does anybody know what these are or can cross reference the following sealing pastes to another type. ie loctite or permatex ?
    1. AMV 188 001 02
    2. AMV 188 188 82
    3 D2
    Oct 2005
    Its weird how no one knows anything about these ... !
    Apr 2006
    Hobart,Tas
    I wouldn't have the foggiest idea! Appears no one has either!
    Best to go to your local bearing supplier as they might be able to cross reference. Bit hard!!
    Oct 2005
    Ok, I know you guys have said that you dont use the AMV 188 001 82 paste for the oil cooler to flange sealant,
    but Bentley again says to use AMV 188 001 02 paste on the G60 block where there is a plate to seal off the hole for the coolant passage into the block on the cam belt side.
    Oct 2005
    I wouldnt even know why this plate is there in the first place.
Similar Threads
  1. Oil cooler sealing to flange
    By aussieg60 in forum Mk2 Golf & Jetta
    Last Post: 25-05-2006, 08:19 PM
