Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
Thread: Vw group parts that fit a mk2 - thread
  1. #21
    You could probably make it fit as long as the curve of both roofs match. Cut the sunroof out including several cm around it and weld to the Golf roof. Big job but I know in Tassie you seldom see sunlight so this way you can enjoy it when it happens.
  2. #22
    May 2012
    Adelaide, South Australia
    Any word on alternative gesrboxes that will bolt up to the 8v?
    Sent from my GT-I9197 using Tapatalk
  3. #23
    Mar 2015
    Perth, WA
    Mk3 Fuel Tank definately fits. Bolts straight in, even the filler neck is the same.
    This is good because you can replace the digipants pumps with the one standard Mk3 pump, that is easier to get and cheaper.
    Also a good way to swop a Carby Mk2 tank and convert to EFI
    Is there a guide nohow to adjust the Mk3 wiring to a Mk2 after swapping the tank over?
    I've sourced a Mk3 tank, straps, fuel filter (new) holder (mk3).
    Just need to sort out the hoses and directions and then the wiring. I have the Mk3 connector and a long length of cables but......
  4. #24
    How many wires are on the plug on the MK3 tank? How many on the MK2?
  5. #25
    Mar 2015
    Perth, WA
    Mar 2015
    Perth, WA
