if the donor car is a passat will it still be plug and play with the mk2 loom?
also will a manual tranny from a 2 litre mk3 GL bolt up to a vr6? or anyone have a manual gbox to suit a vr6? found a wrecked passat (auto) nearby!
hi
it is good you have a 90 spec the wiring is so much easier.
1] if your donor car is a golf you can use every thing apart from the pedal box and rad.
2] if your donor car is a corrado you can use every thing.
3] if your donor car is a passat you can use every thing apart from the cable shift you can use it but it is a bit to long.
to do the conversion it is not hard if you are good with mechanics it is straight forword.
lenzo
Tagedeze Heezy
1991 Mk2 GTI (Auto)
1968 Automtic stickshift Beetle
4cyl and 6 cyl gearboxes are different. you will need to use an 02a gearbox which came in hydraulic (vr6) or cable change (cupra).
You need a VR6 manual gearbox, cupra box is not the same.
hi
yes it will be plug and play the vr6 wiring loom there will be 3 white connecter that go into your mk2 fuse box f,G1,G2 then there is a seperate red/yellow wire with a red plug that goes to one of the permenant live on your fuse box. use the vr6 gearbox if you can get a corrado vr6 box as the gears are better ,
lenzo
i have seen ppl saying b3 passats are good for vr6 conversions. are the b4 the same can you use most of the parts from b4 passat.
