Page 6 of 6 FirstFirst ... 456
Results 51 to 56 of 56
Thread: VR6 into a Mk2 FAQs
  1. #51
    hi
    it is good you have a 90 spec the wiring is so much easier.
    1] if your donor car is a golf you can use every thing apart from the pedal box and rad.
    2] if your donor car is a corrado you can use every thing.
    3] if your donor car is a passat you can use every thing apart from the cable shift you can use it but it is a bit to long.
    to do the conversion it is not hard if you are good with mechanics it is straight forword.
    lenzo
  2. #52
    Nov 2006
    Ro-town, Melbourne
    if the donor car is a passat will it still be plug and play with the mk2 loom?
    also will a manual tranny from a 2 litre mk3 GL bolt up to a vr6? or anyone have a manual gbox to suit a vr6? found a wrecked passat (auto) nearby!
    Tagedeze Heezy
    1991 Mk2 GTI (Auto)
    1968 Automtic stickshift Beetle
  3. #53
    Oct 2006
    4cyl and 6 cyl gearboxes are different. you will need to use an 02a gearbox which came in hydraulic (vr6) or cable change (cupra).
  4. #54
    Camden, Sydney
    You need a VR6 manual gearbox, cupra box is not the same.
  5. #55
    hi
    yes it will be plug and play the vr6 wiring loom there will be 3 white connecter that go into your mk2 fuse box f,G1,G2 then there is a seperate red/yellow wire with a red plug that goes to one of the permenant live on your fuse box. use the vr6 gearbox if you can get a corrado vr6 box as the gears are better ,
    lenzo
  6. #56
    Mar 2008
    qld
    i have seen ppl saying b3 passats are good for vr6 conversions. are the b4 the same can you use most of the parts from b4 passat.
