Results 1 to 10 of 56
Thread: VR6 into a Mk2 FAQs
schwartza3 VR6 into a Mk2 FAQs 03-12-2008, 04:37 PM
Jarred VR6 into a mk 2, is much... 04-12-2008, 09:32 AM
DVR68U for the cars before '91 you... 04-12-2008, 12:39 PM
Golf Loon Just moved this thread over... 05-12-2008, 09:17 PM
Spyda i cant wait to find a wreaked... 05-12-2008, 11:51 PM
    Dec 2007
    Melburg East VIC
    VR6 into a Mk2 FAQs
    hey matt, since you've done a vr6 conversion into a mk2 could you tell me roughly how much i would be looking at? (everything supplied)
    also, vr6 into a mk1?
    cheers
    1.8T AGU | K04 | GIAC | 380cc | VR6 MAF | Custom Intake | FMIC | TIP | 3bar FPR | N75J | 42DD 3-2.5" TB | GFB DV | FK Highsport | ECS Stage 1 Clutch | OZ FUTURA
    Jun 2007
    Eastern Suburbs Melbourne
    Quote Originally Posted by schwartza3 View Post
    cheers
    VR6 into a mk 2, is much easier than into a mk 1. I believe it's because of the similarities between the mk 2 and mk 3 subframes and engine mounts.
    AFAIK, Bank on 10K, if you can get parts at the right prices, and do some work yourself. That includes buy a wrecked VR, and using the bits you need, and selling some you dont. Not sure how much labour would be, Matt?
    Brenton is in the process of putting a VR6 into a mk 2. PM him, DVR68U, he might be able to give you some pointers.
    Also this site is pretty handy: http://mk2vr6.com/board/index.php UK based, but plenty of info.
    i like volkswagens
    for the cars before '91 you have to change the whole fuse box and looms when you do the conversion which is harder than the "plug and play" aussie delivered mk2's but still do able. you'd want to be able to do it yourself or its gunna cost you alot of money all up . prob the same as a cheap mk4 gti lol
    cheers brenton
    MK1 4door
    MK2VR6
    MK3VR6
    Transporter
    and untold wrecks
    Camden, Sydney
    Just moved this thread over from the classifieds.
    This question does get asked, so lets have a thread for it.
    The Golf VR6 is an A3 Chassis Car,
    The Mk2 Golf is an A2 chassis, which has the same boltin points for the subframe as an A3, so if you swop the subframes, the VR6 physically bolts straight in.
    You would retain the driveshaftss, wide track and big brakes of the VR6 and probably swop the rear axle and 5 stud pattern to match.
    If you use a post 90 model Golf 2, the fusebox is the same as the Mk3, so its basically plug and play with the wiring loom.
    If doing it to a small bumpered early car, you would use the whole vr6 car loom or splice in the A2 rear loom.
    You still need to work out the dash, and make it all pretty.
    Then $1000 for engineering and same again for rego.
    A Seat Ibiza or Cordoba is an A3 Chassis car, so is the same swop.
    I did one of them.
    Into an A1 chassis car, the job is very hard as they do not have separate subframes, and engine mount fabrication and chassis strengthening is required.
    Better to drop in a 20VT into an A1 I reckon.
    VR6 Mk 1 was done by Jim Cotton at Awesome GTI in the UK in 93, you could do a search and find that car on the net.
    As far as I know there are 2 Golf 2 VR6s in Australia, one built by dvr68u and one built in 95 by James Mckinnon.
    There is also my old Beeza VR6, now in the hands of William and 2 VR6 2 Door CL conversions that I know of, a white one in Sydney and a Blue one in Tassie.
    The most awesome build thread ever
    http://web.archive.org/web/200802142...ts/89clvr6.htm
    Brentons one
    http://www.vwwatercooled.org.au/newf...hlight=vr6+mk2
    James` Old Car
    http://www.vwwatercooled.org.au/newf...ad.php?t=16504
    Others
    http://forums.vwvortex.com/zerothread?id=4068407
    http://cultstyle.pl/kefirpolo.htm
    http://www.bb-automobiltechnik.de/bb...lo_vr6_28t.php
    http://vwzone.pl/index.php?modul=uzytkownik&id=200
    http://forums.vwvortex.com/zerothread?id=2862410
    Feb 2007
    i cant wait to find a wreaked vr6. So much info is available it should be a walk in the park, or at least as close to a walk in the park as an engine conversion can get.
    MK1 GLS 3door
    A4 B7 2.0T
    Oct 2006
    Golf Loon, what abt the 1.8t from MkIV GTi, Audi etc into a Mk3 Golf/Ibiza? Easy?
    Camden, Sydney
    Quote Originally Posted by Spyda View Post
    Sure it is. Thats why there are so many out there
    If you can get an early VR6 donor 1994, it has the uncoded key and ecu, so less wiring.
