Results 1 to 9 of 9
Thread: Unlocking tailgate from inside?
    Sep 2006
    Hello everyone,
    a burglar broke the lock of my Golf's boot last month, hence the question, does anyone know if the tailgate can be unlocked from the inside? I tried to apply graphite into the broken lock but this hasn't helped at all. Any ideas?
    Cheers people!
    - Nick
    1985 GolfMk2 CL
    Jul 2005
    Melbourne, Williamstown
    well, you could try removing the rear plinth altogether, unscrew the four screws holding it on, and if you can see a long actuation rod inside the mechanism pull it and it should release the hatch.
    Or you could pry the inner plastic panel of the hatch off gently with a flathead screw driver and fiddle around till you get it.
    mk2 GTi 16v
    Corrado G60
    Sep 2006
    Hello Ausgolfer,
    thank's for that,
    do you reckon that this can be done several times? Can the boot be locked subsequent to that, you think?
    Sadly, management doesn't authorise photos anylonger.
    Cheers.
    1985 GolfMk2 CL
    Jun 2006
    Hornsby
    yer it can,
    mine is locked but i have a actuator on the rod Ausgolfer is talking about so i pop it open from my switch but it remains locked
    90 GTI Mk2 1.8t soon to be with GT28rs
    Boronia VIC
    Quote Originally Posted by nick1234 View Post
    Images
    All images should be hosted through Photobucket or similar hosting service and should be resized to no larger than 800x600.
    Signature images should be no larger than 500x100.
    Avatar images should be no larger than 80x80 or 19.5 KB (whichever is smaller).
    This has long been the case and it has been discussed at length. The forum can't afford the storage or bandwidth to host photos with the user base to which we have grown.
    Pete
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
    Feb 2007
    I removed the lock all together and smoothed over the hole so there is no way to get in from outside.
    Ive got an actuator to pop open the boot by remote or from a button hidden inside the car.
    I learnt this that hard way when the wire to the actuator broke.
    The easyest way to open the boot from inside, take the parcel shelf off and you will see the latch, it will look something like the pic below but should be gold in color. Get a screw driver and simply press the hook thats holding it closed, it should unhook with ease and you shouldnt damange anything. I did it all the time when i was trying to get the actuator to work.
    MK1 GLS 3door
    A4 B7 2.0T
    Sep 2006
    Cheers spyda, you're the best!
    Hello Spyda,
    this is excellant and a big help! I'll go out and try it straight away, mate!
    Have been sick of accessing the boot from the inside since it's a 3-door. I probably won't bother to replace the broken lock then unless I find somewhere cheap, someone will break it again. Will let you know how I got on!
    Thank's a lot for the pic btw.!
    And sorry Peter, I did not upload or attempt to upload any photos for a while and hence was unaware about the changes. Will know for the future.
    1985 GolfMk2 CL
    Sep 2006
    Perfect, mate! Tailgate opened within seconds! Many thanks again!
    1985 GolfMk2 CL
    Feb 2007
    Not a problem mate.
    Hooking up the actuator isnt to hard, the main trick is geting the wires up the hatch door and in to the car. I used a long coat hanger and a bit of tape to round of the edge and hold the wire so that it doesnt get caught on anything while passing it through the hatch. I earthed the actuator to the same place that the tail lights are earthed (it didnt seem to work anyplace shorter) and ran the positive wire back to the front along the drivers side.
    It will take a few hrs but once you get past running the wires through the boot everthing else is prity straight forward.
    If you need pics of how its mounted etc, let me know and ill get some.
    MK1 GLS 3door
    A4 B7 2.0T
