well, you could try removing the rear plinth altogether, unscrew the four screws holding it on, and if you can see a long actuation rod inside the mechanism pull it and it should release the hatch.
Or you could pry the inner plastic panel of the hatch off gently with a flathead screw driver and fiddle around till you get it.
