Results 1 to 10 of 16
Thread: Turbo the gti
VwJunkie Turbo the gti 23-09-2009, 10:58 PM
aus79 :bowdown:... following this... 23-09-2009, 11:02 PM
tommymac im going to go with no, i... 26-09-2009, 01:30 AM
VwJunkie Yeah but my engine is pretty... 26-09-2009, 02:24 AM
tommymac yer but a) it was never... 26-09-2009, 10:46 AM
twin eng, twin turbs To start with im all for... 26-09-2009, 12:18 PM
VwJunkie Thanks for the reply, exactly... 26-09-2009, 02:01 PM
twin eng, twin turbs I would run at least a t25,... 27-09-2009, 09:06 AM
VwJunkie Thanks for the reply mate :) ... 27-09-2009, 12:10 PM
esevwbits sounds like it would be a... 29-09-2009, 10:23 PM
twin eng, twin turbs You could do the fuel... 02-10-2009, 09:25 PM
jeanheide well i have seen people run... 03-10-2009, 01:58 AM
evorobin I got a set of G60 injectors... 03-10-2009, 07:15 AM
VwJunkie Cheers for the replies guys!... 03-10-2009, 09:49 AM
jeanheide haha, thats my exact setup,... 03-10-2009, 03:14 PM
twin eng, twin turbs That sounds awesome... 04-10-2009, 07:10 AM
    sounds like it would be a nice project! would love to see some progress of this when the ball gets rolling.
    As TwinEng mentioned, It's all about correct tuning. As long as your mixtures and pressures are up to scratch, you should be fine!
    Jun 2006
    Orange NSW
    You could do the fuel pressure regulator plumbed in with the turbo, but get a rising rate one like the malpasi designed for turbo boost. It wouldn't be as acurate as an aftermarket computer but with low boost and adjusted on a dyno with a exhaust gas analyser messuring your air fuel ratio it might be ok....
    Mk2 GTI 2 door 1.9l 8v turbo 1st mk2 1st engineered water vw nats 09
    Mk1 twin eng twin turb
    scirocco gti 2.1l 16v turb 6spd
    Audi A4 B5 1.8t
    Jan 2008
    well i have seen people run turbos on their cars with everything stock, you can do it, with only minor configurations, but the question always is how long will it last.
    a head gasket reduction plate costs about 50 bucks at max and if you change your fuel pressure to push in a bit more you can perfectly run a trubo with not many mods, besides the BOV and Intercooler.
    I have seen alot of Mk2's run turbos and superchargers with everything stock, just pumped the fuel pressure up a bit to deliver the fuel and it works just fine, but like said, for how long?
    130k km is nothing really, my engine that i just took apart had 224k km's o it and it was perfect like new. not a single mm out (0.01mm out to be exact) in wear and tear, no oil clogs or oil leaks, everyhting looked like it was new from day 1.
    100k km's is classified as a perfectly run in engine on the older cars. i.e perfect for tuning.
    for me, im still rebuilding my golf right now for a full supercharged conversion with the max settings for everything. (wanting to run 35-40psi boost)
    have everything for it except a crank.
    thing is on hold atm because of funds.
    but anyways you could just bolt on a turbo with no hassles and minimum work.
    cheers
    Jean
    Golf MK2 Project
    Daily car: Audi 90 2.3L 5cyl manual
    "I run everything under pressure, from my supercharger to my blood"
    I got a set of G60 injectors here if you need them.
    Dec 2008
    Launceston, Tasmania
    Talking
    @ Jean- Yeah thats what i thought too, heaps of ppl are running their mk2´s with just a FPR and some new injectors. What you wrote is what i thought too at first, add more fuel, add iintercooler and bov....
    I am not sure yet about a full time job next year so i will start with the build once i have more info on that. In the meantime i have bought a g60 manifold and downpipe to replace the tiny stock one and see what sort of power i get from that. Might supercharge it insetad of turbo but we will see what happens... I could run a little m45 off a cooper without too much engine work right? Thanks for the help again!
    Cheers, Stefan
    ----[ Finished the search for a mk2 GTI]----
    1990 Golf Mk2 GTI
    276* cam
    2 1/4 in straight through exhaust
    H&R springs on KYB shocks
    Jan 2008
    haha, thats my exact setup, m45 from cooper onto mine. Just mine is a complete build with forged pistons etc. And running at close to 2.5bar boost on 8:1 compression
    Golf MK2 Project
    Jun 2006
    Orange NSW
    That sounds awesome jeanheide! My mk2 ran stock internals on 14psi for years making 138 kw atw's till i did a head gasket and thought its time for a full rebuild.. That was with 10:1 compression aswell but an aftermarket computer instead.
    Audi A4 B5 1.8t
