Page 2 of 14 FirstFirst 123412 ... LastLast
Results 11 to 20 of 137
Thread: Tim's golf gti
    Mar 2008
    Yea they're 17s, and I do plan on getting coilovers for them, just not sure when I'll do that.
    Jan 2009
    NSW Australia
    Quote Originally Posted by AusScare View Post
    Yea, I use the same username on quite a few.
    Cool.
    I'm camerooney
    Probably bumped into you a few times in various threads.
    I think I can remember you from the Battlefield 2 threads at one stage.
    Camden, Sydney
    Car looks good mate. nice to see a mk2 on something other than the terrible stock metal rims that everyone threw out back in the day.
    Mar 2008
    Small problem maybe, was driving around tonight for a few hours and the alternator/battery light started coming on intermittently. Not sure if its a loose connection being knocked around on the bumpy roads or not. Would come and go every now and then over about an hour. Ideas?
    edit: Had a look under the bonnet today, one of the belts around what I thought was the alternator had tiny cracks between each of the teeth. Would this make it slip or give off a warning note? I'll go for a drive later and see if it still happens.
    edit: And what are my options for front speakers? Links to where I can buy door speaker shrouds? If I can't have front speakers then I was just thinking of upgrading the rear 6x9s...
    Mar 2008
    Installed my new alpine headunit with the help of oliver today, was a bit of effort with all the wiring - old conections ect.
    Really happy with the sound quality and looks great, aswell as the ipod connection.
    Also got a wave from a blue jetta today aswell as passed black polo gti with VW GTI plates.
    Jun 2006
    Thornbury, Vic
    Alternator belt doesn't have teeth I don't think, but if it's slipping at all the light will come on. Mine used to do it in the wet all the time.
    Front door speaker pods are only available from O/S as far as I know, and they're quite pricey from memory. I gave up on that idea. Just upgrade your rear shelf speakers and if you're wanting more, put a small sub in the boot and some decent 3-4" speakers in the dash in place of the old crappy standard ones. Personally I'm pretty much happy with decent 6x9s in the parcel shelf.
    Dec 2008
    Launceston, Tasmania
    Hey mate,
    Im running Kicker 6x9's in the back, standard ones in the front and a sub in the back. System is well capable of making the whole car shake I would leave the fronts, they are pretty good and will do a good job. My advice would be to get some decent 6x9's and maybe add a sub... Awesome car btw man, same colour as mine, running 17's on mine too, they make the car look so high tho.
    Cheers, Stef
    ----[ Finished the search for a mk2 GTI]----
    1990 Golf Mk2 GTI
    276* cam
    2 1/4 in straight through exhaust
    H&R springs on KYB shocks
    Mar 2008
    Anstead, Brisbane
    Quote Originally Posted by VwJunkie View Post
    Hey mate,
    Cheers, Stef
    The fronts do need replacing or disconnecting as they are damaged and crackle a fair bit. Sounds pretty good just through the 6x9's and the new head unit made a considerable improvement aswell.
    We were at jb and guy said would be $95 for putting splits in the front regardless of how long it takes, is it easy to replace the front one? had a quick look and seemed real awkward.
    regarding the alternator, it was wet both times we noticed the light coming on, comes on then goes pretty quickly, stays off the majority of the time though.
    Daily - 2007 Polo Match
    Project - 1991 Mk2 GTI (Track Project)
    Mar 2008
    Oliver came over again today and helped out by re-doing the rear speaker wiring so that it was hidden away and sat flush with the underside of the parcel shelf. We went to Supercheap and got some new fuses and also a bulb for the boot light which oliver also set up again. The rear top brake light is now set up again (previously had fallen off).
    So it's good to see all the little things being fixed up, this week I'll be getting the quote for the front right fix.
    While at supercheap I picked up some Forever Black and reblackened the dumpers and side skirts and the rest, all turned out really nicely.
    I'm going to make a list of all the little things that need doing, then work on them over time.
    More pics to come after a wash tomorrow.
    Mar 2008
    Rained all of today, so no wash. Instead, fitted some ropes up so that it lifted the rear parcel shelf when the hatch opens. The gas struts are on their last legs I think, they need a good helping hand to get to the top.
    Here's a pic showing the redone cabling of the speakers in the boot, and the second pic shows the rear shelf ropes.
    Also degreased the engine bay today.
