would a radiator flush solution do anything? That's a guess.
Also have you doubled checked the cable that controls the door in the heater box? Mine slips so it doesn't close properly and gives only warm air
yes its that time of year in victoria where most of us just cant do without the beloved heater, i have a question![]()
I need opinions on the easisest way to clean out a heater core that is slightly blocked, its not leaking water, its blowing warm air, but not hot, so if you guys could chuck some of your opinions on here, would be much appreciated
85' MkII 1.8 K-jet(small Bumpers) SLAMMEDDD!! ( sold)
91' MkII GTI sold!
Put ur mouth around the exhaust pipe and blow hard.
Did you try what Volkspower said? Didnt it work?
MK1 GLS 3door
A4 B7 2.0T
Mine hasn't worked for the 9 years I've had my mk2. Had a different one from an Aussie mk2 fitted and it still doesn't work. Not sure ifthe cables and hoses are connected correctly though. It's time I fixed it.
mk2 GTi 16v
Corrado G60
Had to scrape the ice off the windscreen the other day. Might be time to get my heater working too.![]()
1978 MK1 2.0 16v http://www.vwwatercooled.com.au/foru...-46488-70.html
1991 MK2 GTI 2.0 8v, white (RIP) and it's red replacement http://www.vwwatercooled.com.au/foru...gti-42078.html
1997 MK3 CL http://www.vwwatercooled.com.au/foru...ml#post1292061
2001 & 2002 Bora 4motion. http://www.vwwatercooled.com.au/foru...st-123823.html
I'd imagine all you Vic/Nsw folks must thing I'm a sook
But I hate not having heat either, I consider anything below 15C way to cold
Bring on 35C + summer days!!! Oh thats right, my A/C doesn't work either
I'm talking -5 down my way when Winter really hits.
