Results 1 to 6 of 6
Thread: in tank upgrade
    Jun 2006
    Hornsby
    in tank upgrade
    guys the stock set up looks pretty permenant but im wondering if you can stick a 040 in there? with out wrecking the fuel float unit
    I know we got a few turbo'd ones and two;s on here so any thoughts
    Jun 2006
    Orange NSW
    I have turbo's on my mk2 and mk1 and with fuel flow tested under full power dyno runs i didn't need to upgrade to a larger than standard pump as the k-jet pump flows enough for my setups, though i dont know how much horsepower its limit is.... If your doing a big horsepower engine and need to upgrade your pump to the 040, im sure it can be modified to suit.
    Mk2 GTI 2 door 1.9l 8v turbo 1st mk2 1st engineered water vw nats 09
    Mk1 twin eng twin turb
    scirocco gti 2.1l 16v turb 6spd
    Audi A4 B5 1.8t
    Jun 2006
    Hornsby
    ok kool, can i clarify the 8v gt'is ran digifant 2 with k jet fuel systems?
    Camden, Sydney
    I reckon you should change the main pump under the car for a brand new kjet pump.
    The lift pump in the tank doesnt do much and should be adequate for your needs.
    Jun 2006
    Hornsby
    as in just a straight swap? im confused about the feeling systems here, so digifants used a kjet fueling system?
    Camden, Sydney
    You get the hose that comes from the tank and connect the kjet pump inline to the line that goes to the engine.
    Remove the whole digipants pump and accumulator and sell it to someone doing a 2L efi conversion into a Golf1.
    I have the Scirocco lift pump and a kjet inline pump in the rocco and it works fine.
