Sounds like it could be your power steering pump? have you checked out all your front end? could be something amiss in there.
hi all
just recently my steering has become very stiff. it is particularly bad in reverse but also happens when driving. it doesn't happen all the time so i figured it was power steering fluid or a belt. well i replaced all the belts and the power steering fluid reads FULL. someone told me to leave the car idle and go full lock one way then full lock the other way then open the power steering fluid cap and let the air out? well this did nothing either!!! its dangerous aswell. sometimes down shifting to second to go round a corner the steering locks completely for a second or so.
does anyone have any ideas what it could be?
cheers
1991 mk2 golf gti
1974 beetle 1600 s
mk1 16V hybrid/bitzer
Yeh I reckon it sounds like the pump at this stage, unless the new belt for the pump is loose
2nd hand pumps can be quite dodgy & cause a lot more problerms
I know this as I have just gone through all of this
Cheers Ian
Power steering pumps are hard to test without specialised gear. The easiest (but probably the least reliable) way is to remove the belt and if it continues to behave in the same way the pump is the likely culprit.
I would the try the belt at different tensions first before geting a new pump
GTI has them in stock for $265
Cheers Ian
A new pump from the stealers would set you back about $500when I last asked earlier this year.
MK2 GTI G60
