Reostat in the headlamp switch mate give it a tap like the guys say. Sounds like you will need a new one. On the play thing mate just check the allen bolt that clamps the ign housing. There is a hole in you cowling to get access to this on the left under ind switch. The size of the bolt is 6mm. sometimes they fit a shear bolt. if not you will need a new ign housing and there is a little trick to remove the ign barrel- can be done in place
Alba European
