Results 1 to 10 of 12
Thread: steering help
    May 2006
    steering help
    hey just noticed a new problem with my car (mk2 Gti)
    when i accelerate the steering pulls to the right..i lift off throttle and it steers straight,, then i brake and it pulls to the left... this is worrying because i had the wheel alignment done about a month ago.. any help to what it is...i can also hear a knocking sound when braking any help there? ?
    Golfwise Guest
    Head off to your garage.Its a ball joint or loose bolts not tightenrd up by the wheelaligner.Wouldn't be the first time.
    Camden, Sydney
    Yup the wise one is right. Go back to whoever did the job.
    Do it soon, it will only get worse.
    May 2006
    yeh..so its the wheel alignment ...ok..they should do for free right haha..
    syncro Guest
    I had a '76 swallowtail that did that. Turned out to be a 900mm crack in the body allowing the left stub axle to move forward about 30mm. Those Australian assembled swallowtails really were ****boxes.
    May 2006
    dont say that mann !... so the most likely problem is the loose bolt or whatever ?
    Canberra
    The bolts at the front of the subframe can come loose as well. This has happened to me twice. But it is most likely going to be a ball joint...
    Euro look 2... Mk2 love!
    May 2006
    ok so cost ? ?
    Canberra
    If bolts, nicks if you can jack the car up and have a 19mm spanner. If ball joint, I have never needed to replace one, but I would budget for about $100-150.
    sydney
    take it back to the cowboy who supposedly did the first allingment and get him to sort it, dont pay him anything
    I would have gotten wood from the picture message you sent me.. But I was sniffing Nitro, so i already had it. Hahaha.
Similar Threads
  1. Replies: 31
    Last Post: 09-10-2006, 08:34 PM
  2. steering drivetrain and heartache
    By gldgti in forum Mk1 Golf
    Last Post: 04-06-2006, 09:25 PM
  3. Rack Ends solution. steering rack problem fix
    By Edison in forum Mk1 Golf
    Last Post: 10-05-2006, 09:27 AM
  4. New improved dynamically variable steering!
    By Peter Jones in forum Mk1 Golf
    Last Post: 22-11-2005, 09:56 PM
