Results 1 to 8 of 8
Thread: Speedo breakdown
    May 2006
    byron bay area
    Speedo breakdown
    Hi all
    I was driving along on the HWY today & the speedo suddenly cut out, with no warning. It has never done this or played up in any way before
    Has anyone had experience with this or know what the problem is, before I start pulling things apart??
    I suppose that it would be the cable has given up or a probem in the actual speedo itself
    cheers Ian
    Cable could have fell out of the back of the clocks or maybe the plastic drive in the gearbox has broken up.
    Last one would be a broken cable but I haven't seen one do that personally.
    May 2006
    byron bay area
    Is it possible to check the plastic drive in the gear box without opening the box
    Yeah, 11mm socket to undo the clamp bolt. Pull the cable out and the drive should be on the end of the cable. Most seem to be red.
    May 2006
    byron bay area
    That sounds staight forward & alot more easy than playing around behind the speedo cluster, I'll check it out tomorrow before I look behind the speedo as I really don't want to take the cluster out
    I will let you know what happens
    cheers Ian
    May 2006
    byron bay area
    I checked the drive gear & it was in good condition, but the cable has snapped off inside the sleeve about 600mm up from the gear. So I guess I'm up for a new cable after all
    Thanks for the tip!!
    Regarda Ian
    Boronia VIC
    Quote Originally Posted by aliasmk2 View Post
    Regarda Ian
    Don't reconnect the broken cable. Tape it up out of the way somewhere until you can fit a replacement, I've heard some nasty tales of the gearbox ingesting the broken cable!
    My 2cents worth!
    Pete
    May 2006
    byron bay area
    Thanx for that Peter
    That sounds dangerous & costly if it falls in, but I've heard of them falling in & not having any effect on the gearbox, even years later
    So I've taken your advice & moved it out of the way until I get the new cable
    Regards Ian
