Cable could have fell out of the back of the clocks or maybe the plastic drive in the gearbox has broken up.
Last one would be a broken cable but I haven't seen one do that personally.
Hi all
I was driving along on the HWY today & the speedo suddenly cut out, with no warning. It has never done this or played up in any way before
Has anyone had experience with this or know what the problem is, before I start pulling things apart??
I suppose that it would be the cable has given up or a probem in the actual speedo itself
cheers Ian
Is it possible to check the plastic drive in the gear box without opening the box
Yeah, 11mm socket to undo the clamp bolt. Pull the cable out and the drive should be on the end of the cable. Most seem to be red.
That sounds staight forward & alot more easy than playing around behind the speedo cluster, I'll check it out tomorrow before I look behind the speedo as I really don't want to take the cluster out
I will let you know what happens
cheers Ian
I checked the drive gear & it was in good condition, but the cable has snapped off inside the sleeve about 600mm up from the gear. So I guess I'm up for a new cable after all
Thanks for the tip!!
Regarda Ian
Thanx for that Peter
That sounds dangerous & costly if it falls in, but I've heard of them falling in & not having any effect on the gearbox, even years later
So I've taken your advice & moved it out of the way until I get the new cable
Regards Ian
