Originally Posted by
Golfer
Peter Jones
I ordered in a new ignition module and hall effect module for the ignition. I had them sitting on the shelf for about a week when the old ignition module in the car blew up one morning. I was pretty pleased with myself for anticipating that one!
I'll change out the distributor module once I've got the motor started back up. I don't want to change everything all at once, it gets too hard to fault find.
Hey Pete,
Mate I've been having major dramas with my car, it is not getting any spark whatsoever. At first the problem would come and go, sometimes the car would restart right away, other times it would leave me stranded on the side of the road for an hour, then the car would start. It is definitely a problem with the ignition system, but I have no idea what it could be... The coil is good, but beyond there I didn't know what I need to look for.
Were your problems in any way similar to mine? I'm tearing my hair out trying to figure out the cause of my woes, any help would be SO SO SO appreciated!!!
BTW, are you putting your timing cover back on or leaving it off? It looks fantastic off with all the pulleys painted, but will that have any possible adverse affect?
Cheers mate. Well done on the work you're doing to your beast!
John
Hi John,
The covers are off for the foreseeable future, the collective wisdom was to not bother. I think it was Henry Ford that said something along the lines of "Parts left off cost nothing to install and never need to be replaced".
With regard to your issues, Here's my thoughts.
Coil.
Needs to be one specifically for electronic ignitions. Mine's a Bosch transformer style coil similar to the new style GT40 coils.
Ignition module.
This is probably the culprit. Mine failed totally and suddenly with no warning signs. Other cars use the same system, the most common is the later Camiras, TD I think. These are a very common thing to fail. Any auto sparky will know what it is and will be able to get you one.
Distributor module.
The sensor in these can fail. The entire module is available as a part or some people have been able to replace just the sensor with a Jaycar equivalent Hall Effect Sensor.
Wiring.
Mine was a complete mess. Check the connector at the ignition module and the coil. I found that the connector on the distributor can hold water if the boot is cracked and this causes corrosion of the terminals. Clean all the plugs and sockets with contact cleaner and then give them a dose of WD40 to keep them dry.
I'd probably try and find a friend with a similar ignition system to swap bits over 'till you work out what's at fault.
I'd try cleaning all the plugs first, then replace the ignition module then the distributor module.
Sometimes you can get lucky and pick up an ignition module at the wreckers for $5.
Worst case scenario you can install a 1600 dizzy in there and dispatch the electronic system but I'd stick with it and sort yours our.
I'll send you some photos after I've had some dinner so you can identify the parts.
Pete
