Going back to my Hijacked post, I put the new head on with the GTI cam in it and the car goes. Initially it was slowere, then I twiddled with the timing a bit and it goes hard again now.![]()
There ya go ! The reason why VW have always specifed their own anti freeze.....G10, G11 , G12 and G12+ i think now......
got G12+ in my mk1, crystal clear coolant !well....almost, its a bit purple......
To hijack to post further
Red Line Water Wetter, i used demineralised water and a bottle of water wetter (its like 500ml). I was talkign to an american bloke and he reckons it takes the so called "hot spots" out of the vdub watercooled heads and dosent corrode. It has dropped my water temp by about 10deg from max, i am a huge fan of red line products. I think it is about $15 for a bottle
76' Mk1 Rally Car, 1800 8v haltech ecu
94' Fairmont Ghia, v8, big cam, leather, perfect for towing golfs
89' EA ex taxi, lpg, cheap and easy
Diesels have thicker metal around the water jacket in the head. The idea is to disperse heat more evenly. Works fine but reduces the total volume of water circulating in the head and creates "hot spots". This is one of the reasons that diesels cark it so quicky if you overheat them. The idea of anything that overcomes the problem must be good.Originally Posted by golfnutracing
