Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
Thread: So I'm going to look at a 1990 Mk2 GTI...
    Sep 2010
    I really have next to no info about the car so far...if it's an import/16v/8v etc
    I'm not really to fussed over the whole import vs Aussie stocky debate...I have read a few threads already in my searching, I wouldn't want to re-ignite that!...
    It has 5 doors and a quarter panel on the back doors...so this would be 8v Aussie I imagine?
    What are some key things I need to look out for?
    It may seem obvious to you guys but I'm looking for my first Golf and kinda want to get this right...it is coming unrego'd and no roadworthy.
    It is the gamble out of the final 2 I have narrowed it down to I think...
    Thanks in advance!
    Apr 2008
    Does it have big plastic bumpers on it or small ones with metal panels underneath them.
    As I bought one in the same condition I'd check the following.
    Does it idle properly?
    Check the CV boots for tears.
    How's the front drivers seat for wear n tear?
    Does the heater work? The heater cores are known to fail. What about the A/C?
    Check for rust under the windscreen, especially in the wiper holes.
    Obvious stuff like coolant or oil leaks.
    Does the central locking work? You should be able to activate it with the key from the drivers door.
    Check the foglights work. They are expensive to replace.
    Does it crunch into 2nd gear? That's a common fault.
    Hopefully the rear parcel shelf doesn't have speakers cut into it.
    Quote Originally Posted by Depone View Post
    Which 2 have your narrowed down ? Ben has listed out almost everything, I'd check MFA if you fuzzy about it.
    Sep 2010
    I have narrowed it down to Kozteks Mk2 and this other one I have found...There is not alot of info about it and the pics are not great at all that I do have of it.
    That list is all really helpful stuff thanks!
    Being such a newbie to Golfs and tbh cars in general it is a risk...but I will get it checked by RACV if it looks worth it.
    What is MFA :/
    Sep 2010
    http://img34.imageshack.us/img34/435...qmokiceyvl.jpg
    images are'nt working so here are some links
    Sep 2010
    black FTW
    Velly
    '91 2.0 8v GTI
    Quote Originally Posted by DubSteve View Post
    I have wood thinking about you
    Sep 2010
    Yeah I hear ya, that black is tough as f*ck! But I don't want to be basing my purchase on the colour! ( when from what I can see Kozteks red mk2 is clearly in good running order )
    That list is a good start, I will have it with me when I check it all out on Sat.
    May 2010
    NQ
    My first (and current) car is a MK2 Golf GTI, love the thing to bits.
    But be prepared to be working on it atleast once a month (they're old cars!) Im usually fixing or replacing somthing on my car every fortnight.
    Also be prepared to buy parts that arn't from local stores but instead from over sea's.
    Walking into a auto store like Supercheap, Repco, Autobarn ect, to buy parts is not an option. Luckly your in Melbourne though, you might have better luck with VW suppliers down there.
    That said, they are great little cars that will last forever.
    Also I might add, check for rust around the outter door rubbers in the frame of the car (particularly the back bottom) as I found rust in these area's on both sides of the car (I can throw a pic up if you need).
    I paid $5000 from mine and I'd consider it to be in relativly good condition.
    You'll enjoy the first test drive
    PS: MFA is the Multi Function Indicator at the bottom of the instrument cluster, its a little digital screen that can tell you the time, oil temp, fuel use per 100km (L/100km) and also your RPM aswell(?). Theres a little switch on the wiper stalk to change 'mode' between what info you want displayed. (mine doesnt work, only tells the time)
    Sep 2010
    Yeh I have kinda gathered that so far thanks, been doing a fair bit of research the last 2 weeks since I have decided to get one.
    Thanks for the info on the MFA, hope that set up works on this one sounds very handy.
    I realise this one is a bit of a risk but I've got to check it out....
