Does it have big plastic bumpers on it or small ones with metal panels underneath them.
As I bought one in the same condition I'd check the following.
Does it idle properly?
Check the CV boots for tears.
How's the front drivers seat for wear n tear?
Does the heater work? The heater cores are known to fail. What about the A/C?
Check for rust under the windscreen, especially in the wiper holes.
Obvious stuff like coolant or oil leaks.
Does the central locking work? You should be able to activate it with the key from the drivers door.
Check the foglights work. They are expensive to replace.
Does it crunch into 2nd gear? That's a common fault.
Hopefully the rear parcel shelf doesn't have speakers cut into it.
