Results 1 to 10 of 16
Thread: Loose Steering Column
    Aug 2009
    Darwin, NT
    Hi guys,
    There is some looseness in the steering column of my Golf, slight play both horizontally and vertically, as if there was too big a gap between the steering column and the column tube; I can also sometimes feel this while driving (especially over bumps, as you would expect) - it's not major but annoying enough. I'm pretty certain the looseness is somewhere in the top section of the column. What could it be? Is there a bearing that potentially needs replacing? How do I go about replacing it, should that be the case? Any feedback would be greatly appreciated.
    Cheers,
    Dom
    - Mk2 Golf GTI 16v, 2-door, Tornado Rot, BBS RS, 1988 - SOLD
    - E30 325i Coupe, Manual, Alpinweiss
    - E30 325i Touring, Manual, Diamantschwarz x 2
    - On the lookout for another E30 325i Coupe, Manual (red would be nice)...
    Gold Coast
    I had a similar problem, you might need a new steering rack bush VW Heritage for VW parts and accessories
    Having said that MK2's have collapsible steering column so it might just be a bit of play as a result of age.
    May 2010
    NQ
    MK2 - *Insert list of dealer purchased extra's/standard features here*
    80 series - The MK2's BIG, Sooty, polar opposite...
    HAHAHA
    Gold Coast
    Quote Originally Posted by ryana89 View Post
    How come i've never seen that website before!
    Learn't most of the stuff on there by trial & error (mostly error).
    Aug 2009
    Darwin, NT
    Thanks Walshy and Ryan. Found this page you are referring to last night after posting up the question on here - I think this is what my problem is. Do you think I will need to remove the whole column out of the car (not too keen on removing the clocks, as per this guide: How to Remove MK2 Golf Steering Column - VW Golf GTI Guides) just to remove the bearing? Also, where do I get the new bearing (checked all the usual places online)?
    Cheers guys!
    Dom
    May 2010
    NQ
    Quote Originally Posted by Domel View Post
    I can only imagine a local bearing supplier would be the best bet?
    ECS use to carry them, but not anymore apparantly.
    HAHAHA
    Aug 2009
    Darwin, NT
    Thanks Ryan. Drove the car today trying to focus on the loose column, and actually it's not that bad (I think I'm just still used to the e30 where everything is very tight). I will probably want to look into fixing this eventually, but will probably get the car lowered first
    May 2010
    NQ
    Haha, you should hear the sounds that come from my steering column when going around/through a corner.
    HAHAHA
    Nov 2009
    I've just done the top and bottom bearings on a MK1 (which I think are the same?), with the column in place. Massive difference, no play at all now. Parts are easy to get from most places in the US or UK.
    Aug 2009
    Darwin, NT
    Quote Originally Posted by Vinda76 View Post
    Thanks for the post mate! Where did you get the bearings from?
    I think replacing mine would make a significant difference, too. I think everything else being pretty tight only further amplifies the steering column bearing issue.
