Results 1 to 9 of 9
Thread: Small Bumper Golf Side Trim
    Jan 2009
    Sydney, New South Wales
    I've just bought an Aussie spec mk2 golf and am chasing up trim for her as previous owner took his off. Currently I have one set of the big bumpers arches and trim but the side skirts are stuffed, but I've also aquired some mk2 small bumpers arches which aren't as fat at the bottoms but it dosen't match the thin door trim.
    Was wondering if anybody had some of the thicker door trim off small bumper golf or where to get them as i'd prefer them then the original arches as they are stuffed, Im also going to leave off the side skirts as they seem to not want to stay on (I'll probably just spray the side).
    If anybody has some tips or tricks as to what I should do or any other preferences then that would be great.
    I'll have a full post of the work done on this car with pics later when my internet isn't capped, cheers.
    Dan
    Jan 2009
    Also its a 5 door
    Jan 2009
    If i was going to attach the original side skirts, what is best to keep them on
    I reckon you will find that once you take those narrow side trims off you'll have holes in the doors. The wide early trims sit in a different place on the door and won't cover them IIRC.
    Feb 2009
    NSW
    Early trims are stick on and sit below the waist line, where the later strips sit above them.
    Jan 2009
    So I've got the early trim, is it going to be a problem attaching them, will the holes be in a different spot, therefore cause a problem?
    Dan
