Results 1 to 10 of 10
Thread: Sloppy Shift
    Dec 2005
    Question Sloppy Shift
    hi all
    i have a mk2 GTi and am having a few problems with the gear shift. The gear stick is really sloppy and sometimes wont go into gear properly. For example often when changing from 5th to 4th or 3rd to 2nd it doesnt grab the gear and makes a crunching noise. I have replaced the bushes on the gear linkages but this hasn't helped. Any ideas on how to 'firm up' the throw?
    1991 mk2 golf gti
    1974 beetle 1600 s
    mk1 16V hybrid/bitzer
    What bushings have you changed?
    Have a look for dieselgeek they have a great product for mk2s that makes a load of difference.
    The crunchy second gear is likely to be the syncro gone. Fully synthetic gear oil helps a lot without changing the box out.
    Jul 2005
    Melbourne, Williamstown
    also you might need a new ball and cup which encorporates the actual gear stick, pain of a job that I haven't gotten around to doing myself.
    mk2 GTi 16v
    Corrado G60
    Apr 2006
    Asaka-shi Saitama Japan (from Tassie)
    sounds like the syncros to me.
    mine grinds a bit going into second....but only when its cold.
    Cheers, Benny
    www.axesent.com.au
    Dec 2005
    i looked on diesel geek website and i cant find this product. all i can find is short shift kits. what is the product called?
    1991 mk2 golf gti
    1974 beetle 1600 s
    dude sorry mate, I found a link I emailed to someone last year and the page has gone. All it was, was a square block of nylon with a hole drilled in it. On the car you have a round bit that falls to bits over time.
    Maybe an email to dieselgeek would get you one?
    http://www.dieselgeek.com/Detail.bok?no=284
    this was the link.
    Dec 2005
    evorobin reminded me to let you know that the throw is really long particularly into 2nd gear
    1991 mk2 golf gti
    1974 beetle 1600 s
    The throw is massive full stop. Having had two 02 boxes it was never that bad tbh.
    Apr 2006
    Carlton, VIC (HK now)
    i had similar problem in my Mk3 before...
    maybe not the same thing to yours
    at some of the times the car just doesn't want to go into gears
    went to the mechanics and the previous owner put wrong trans. oil in it
    so then we put some valvoline in and it works much better!!
