i had the same trouble recently...
i have a mk1 but i asume they are the same under there.
underneath where the shifter i (under the car) there will be a boot...you must remove this so you can see a foot like shape and a box section.
the foot moves around when selecting gears.
where the linkages connect to the chassis there will be a hose clamp type clip with a 13mm nut you need to undo this. then find a match box or measure 15,, out between the box under the shifter and the end of the foot.
then tighten up the clamp and check it... undo the clamp and swivle the foot until it selects all the gears nicley. (may take a lil while).
if you need clarification just ask
Stu
