Originally Posted by
Alex Mckenzie
Question.
I’ve read when setting timing, you need to get car to normal operating temp, unplug green temp sensor, rev to 3k back to idle 3 times, set the timing at 2250 rpm, when you set it,is the green plug re connected or is the green plug still off when setting 6 degrees BTDC @ 2250. ?
What is the best way to confirm you green sensor is still working ?
When I unplug the sensor the revs normally go up about 100rpm ( if the radiator fan is going I don’t think the rpm’s change)
Questions, question, question
